Champ window regulator
  • Body / Glass: Champ window regulator
    Is a 1960 Champ window regulator the same as a Lark or another Stude car?
    Same as earlier Larks, '59-'60, but not necessarily later sedans.
      Thanks
      Do you have a part number
      Is this available as I cannot seem to find them. A power window conversion might be a solution?
        My 7e parts book shows regulator 1343100 (R) and 1343101 (L). Earlier ones are 1314350 (R) and 1314351(L).
        Those doors are the same as sedans through '62 - so as long as the mount holes and lower window bracket are the same, you should be good. Good luck.
          I have good used. $100 + shipping.
            1962 and later Champ pickups used the single stud regulator that was used only on 1962 Lark sedans. (Y, F, and P body)
              Confused now
              Is my 1960 Champ the same as a Lark to 62?
                Originally posted by Hoghead View Post
                Confused now
                The door on your '60 Champ and a 1962 Lark 4 door sedan (or '62 Champ) is essentially the same. In 1962, the Lark and Champ went to a single stud on the regulator and window bracket at the bottom of the door window. '61 and earlier had a dual stud regulator and door window bracket. As long as you have a regulator and window bracket that mirror each other, you should be good.
                So if you get a regulator for a '62 Lark, make sure you get the door window bracket or else that regulator will not work with your original lower door window bracket.
                The door on my truck came off a '62 Lark 4 door sedan - but because the truck was a '62, the original window and bracket out of the truck fit on the Lark regulator.
                  Got it now - thanks
