back in 1968 I had a 56 commander..left front wheel collapsed under me..upper aA arm mount holes broke out...pulled a 57 champion out of a field, tore it down to the bare frame, found same problem on L side, had been welded up..right side completely blown out and no repair..seems to be a common problem??metal looks good, maybe bad geometery..in process of replacing front stub with mustang 2 stuff..anyone ever run across this?
upper A arm mount
It is fairly common with V8 Studes, especially 56Js. I have seen half dozen with cracks in that area, and a few were ripped out. A Tech Bulletin for a field fix was put out in 1958, to graft a reinforcement plate on the outside of the frame. Later, beginning in 1962, that plate was factory installed, inside the frame, along with a heavier gauge frame.
I believe severe service on secondary roads, i.e. "washboard" bumps on gravel roads contributed to the problem. Thankfully, roads are maintained a little better today.
