i installed halogen headlamps in my Avanti with no problems. if there is something rattling around in the circuit breaker, that's probably the problem. i'd go to NAPA, as stated in Post# 3 and get a newer one. also as others stated, check your dimmer switch and check/install headlamp relay(s).
Head Light Switch Fuse
Originally posted by az64stude View PostYou may want to see how many amps your pushing. I would stay with OEM headlights but its always fun to try different things. What ever you do get that corrected its not fun when your headlights go out. You can swap the breaker with a larger one but make sure your circuit can handle that. Remember your high beam is going to draw the most amps, also do check all connectors for good contact including grounds. GOOD LUCKOriginally posted by christophe View PostDon't forget that you already have in your car a very handy and useful amp meter. Thus, you can check how many ampères are drawned by your headlight. This is obvious but I have a tendancy to forget that myself.
Originally posted by Corvanti View Posti installed halogen headlamps in my Avanti with no problems. if there is something rattling around in the circuit breaker, that's probably the problem. i'd go to NAPA, as stated in Post# 3 and get a newer one. also as others stated, check your dimmer switch and check/install headlamp relay(s).
Originally posted by az64stude View PostI would stay with OEM headlights .
Actually, Halogen bulbs are incandesecnt too, but you know what I mean.Last edited by bensherb; 08-22-2017, 05:31 PM.sigpic
Originally posted by bensherb View PostIf you can still find OEM type incandecsent sealed beams you're doing better than here in California. Here, incandscent sealed beams haven't been commonly available for 25 years, they're all halogen now. It's actually starting to get more difficult to even find any round sealed beam now. I'm sure when I have to replace one on my Stude I'll have to go to reflectors and replaceable bulbs (H4 type) like I've had to with my other cars.
Originally posted by Kato View PostAs for incandescent sealed beams, also a thing of the past here to my knowledge. In fact incandescent bulbs for any use, home, auto etc.. have been all but banned! They call it progress!sigpic
