Just out 0f curiosity, I took a look at the coils from Rock Auto. The only one that listed the resistance was the premium one from Airtex. It shows resistance of 1.2 to 1.9.
Ignition coil differences
The variance between 1.2 and 1.9 ohms is substantial as it could have a major effect on the current draw through the points if the replacement coil primary resistance is 1.2 ohms and the original specified resistance is closer to 1.7 or 1.8 ohms. I've had problems with Airtex electrical components failing short order in the past and as a result, I will not use their parts. My advice is to stick with Standard Motor Parts Blue Streak or Napa Echlin electrical parts as I am not having to replace their parts due to early failure. Bud
Been using a GM HEI modal on a Slant 6 Mopar electronic distributer. Using an early GM HEI inline 6 coil. Eliminates all the resistors and large stuff for a cleaner appearance. Have been using it since 2001 without a problem. Used a VW bug 12volt coil on another engine which I sold,Bosch coil.
Ok kxet, cool! This is what I kinda suspected; I've used different coils I've had laying around & it always worked but looking at speedshops selling coils it's quite a load of them so I thought it would be interesting to know the differences...
Anyway, I'm gonna be picky this time!sigpic
Josephine
-55
Champion V8
4d sedan
