I've made an update to my Excel spreadsheet.
The link below will allow you to download the .xls file from my Google Drive.
https://drive.google.com/open?id=0B_...WZIUVdhODFsNUU
If not IM me with your email..
Once again you can enter your tire size (metric) and 4 rear-end gear ratios and two transmission ratios (up to 5 speeds).
Before it just had MPH that would give you engine RPM per Transmission Gear per Diff Ratio per Transmission
Now you can enter an RPM and it will give you the MPH per Transmission Gear per Diff Ratio per Transmission
The work sheet is locked except Grey cells so you can enter your data,
