Dropping the Oil Pan in a 1946 M15
  • Engine: Dropping the Oil Pan in a 1946 M15
    Dropping the oil pan should not be this difficult. I had to remove the starter and cable to get at the bolts but how do I get the pan out without taking apart the steering linkage. It is close but just will not go. Am I missing something here?
    Did you try rotating the crank to get more clearance or disconnecting and motor mount to raise the engine a 1/2"??
    treblig
      nope will try tomorrow. Thanks for the suggestions. The 1/2 inch should be all I need
        Jacking the frame up, and letting the suspension drop down, might give you a little bit room. Good luck!
          Try a bottle jack between the spring and frame and push axle down a bit, one small one per side. Luck Doofus
