While replacing the inner rubber bushings, I noticed that the mounting surfaces for the OUTER threaded bushings where not parallel - The bottom of the surface measured 0.175" wider (splayed out) than at the surface at the top.
Two questions: will this cause a problem when assembled w/ the threaded bushings torqued to the spec'd 175 ft. lbs.?
And, What is an acceptable error of being parallel? (The surfaces are parallel from the outer surface to the inner surface within 0.007").
There is no spec. noted in the Shop Manual.
Thanking all for your expertise and help,
Paul TK
Paul TK
