Power Steering Pump
  • Steering: Power Steering Pump
    The lid on my power steering pump has a small hole described as a "vent" but when I put the lid on with a washer and the wing nut, the vent is blocked. Do I need the washer?
    Peter Bishop
    Director,
    Northeast Zone
    Peter there should be a rubber disc, then a steel washer, then the wing nut. It vents even though the hole is covered up. My '62 GT has been functioning that way for more than 20 years.
    Frank van Doorn
    Omaha, Ne.
    1962 GT Hawk 289 4 speed
      I will get the rubber disk. Just another step towards authencity. Thank Frank!
      Peter Bishop
      Director,
      Northeast Zone
        Since fluid in the reservoir is constantly increasing and decreasing in volume, there needs to be some ability to vent it, otherwise it will be subject to negative and positive pressures, depending fluid level. Make sure the vent hole is clear.
          There's a raised ridge around the stud where the vent hole is. It has a break in it, like the letter "C". The trick is to get washers, (one rubber and one stainless steel), that are large enough to ride on this ridge. Thus it can vent through the break in the ridge.
          The rebuild kits may have parts for a Ford lid which vents through its fill stack. They block the vent hole and will cause fluid to be forced out.
          Mike M.
            If you cannot find the rubber disc let me know I probably have one that I could mail you.
            Frank van Doorn
            Omaha, Ne.
              Long ago, I switched to the Ford style cover on all Bendix PS pumps in Studes. With the twist cap and dip stick, it is soo much easier to check the PS fluid level. Just another one of those driver friendly mods that ain't, "correct" but I do not care
