Alternator
  • Electrical: Alternator
    Probably a dumb question but is there a modern substitute for the original Prestolite alternator on a 63 Lark Cruiser? They seem to be in the hen's tooth category.
    1979 Honda Civic 1.5L 4 cyl, just about a bolt in replacement.
    Got one a couple years ago from Rock Auto ... a Remy # 14158
    Fred
      I put one of these in my (ex) '64 Daytona-it looked and worked great! Easy install too...
        It probably wouldn't work on a 65 Cruiser V-8 283? I need one.
          Any GM alternator thru about '85 should bolt right on. Try a '75 GM integral regulator unit, you can even get them in "one wire". That "one wire" just goes to the battery +. If you get the standard 3 wire one, get the 2 wire connector for it too, the 1/4" batt terminal goes to the battery+, the large wire on the connector goes to the batt + (the 1/4" batt terminal works), the small wire on the connector goes to the idiot light. I believe the wire on the "F" terminal of the regulator you no longer need goes to the light.
            Since my studes have a Mopar reg. i have been using that alt. good results,as the pestolite alt doesnt seem to last long when rebuilt. local shop has them on hand.their old as dirt and good! mopar alt was one, also GM i was familiar with from working days. prefer "Square Back " mopar for some odd reason. Luck Doofus
              Thanks for the responses. Really appreciated.
              George
                yes, likewise. I appreciate the help.
