Today was discouraging. I got all the components on the 1960 Lark 259 engine that I put in my 52 Studebaker. I put the battery in and then Tom Covington came over. The starter just clicked but the engine didn't turn over. We thought my battery was bad even though I had charged it this morning and I have a volt meter on the dash that registered 12 volts. We took the battery out of Tom's car and it did the same thing.
Tom thinks that I either put the main bearing caps in backwards or I torqued them too tight. I torqued them by the shop manual which calls for up to 93 lbs. I torqued them at 90 lbs.
The engine turned easily before I took the main bearing caps off, because my son and I had to turn the crank in order to get the longer flywheel bolts in the flange. We took the back 3 rear main bearing caps off so we could lift the crank up slightly to replace the rear main seal. We put them in a place and labeled them, but when he handed them to me, I may have gotten confused as to the direction that they went.
We tried to turn the engine by hand with a long bar on the crankshaft nut, but the nut just tightens.
Any suggestions?
Leonard Shepherd
http://leonardshepherd.com/
Any suggestions?
Leonard Shepherd
