Key blank number
  • Other: Key blank number
    Can anyone tell me what the key blank number is for the glovebox and trunk on a 1955 Studebaker President State Coupe?
    thanks,
    Jen
    An expert will chime in-but these might be correct if they are Yale locks, I don't know how to tell the difference, but they may be Hurd and these won't work. http://www.parts123.com/parts123/yb....Z5Z5Z50001003a
    Be patient----SI servers are in need of an upgrade may take a long time to open-maybe more than one try.
    Your local key maker may not even have a blank as these locks are long since out of production-
      Studebaker in that era used Yale locks in the Champion (6cyl) line and Hurd locks in the V8 lines (Commander and President). I am quite certain I have the original keys for my '55 President (4 dr). Upon inspection I was surprised to find the trunk lock key although a Hurd is in fact identical to the Yale key for the same era. If that holds true for your car the source above will work. I believe the key blank number is Y12 which are readily available on ebay at a wide variety of prices. Hurd keys of that era are typically flat on one side while the Yale keys are slotted on each side.
      FYI the original ignition key is a Hurd H4 and it is probably more difficult to find.
      American iron, real old school
      With two tone paint, it sure is cool
      Its got 8 cylinders and uses them all
      With an overdrive that just won't stall
      With a 4 barrel carb and dual exhausts
      With 4.23 gears it can really get lost
      Its got safety belts and I ain't scared
      The brakes are good and the tires are fair.
      Tried to sell her, but got no taker
      I"ll just keep driving my Studebaker
        For my '55 President Deluxe Sedan I purchased the ignition (Hurd) key blank from Studebaker International. The trunk had no key at the time so I took it to a lock smith and he made up a key. That being said the trunk key did not look correct (generic) so I checked with Studebaker International and they have them in stock, my keys now look like they should.
        Hope this helps.
        55 President Deluxe
        64 Commander
        66 Cruiser
        37 Oldsmobile F37 4 Door
          Thanks for the response.
          Jen
