I know I have seen a discussion of this before but I have not been able to search and find it. Can someone point me to a previous thread or explain how to remove and install the tube.
Flat Six (170) Oil filler tube removal / install
First check to be sure that the heavy wire clip is not around the base of the tube clamping it to the nub on the end of the starter motor.
The grab the tube and wiggle/rock it, moving in a circle while pulling up on it.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
I tried getting mine out by clamping blocks on with hose clamps and tapping on them. That did not work so I ended up tapping it out from the bottom with the oil pan removed. I would have left it in place but in my engine it blocks access to a core plug.
Roy, I am referring to fill tube not the dip stick tube.
nvonada, I assume from your response that this tube is just a pressed in piece. No type of clamping bolts or clips or clamps, etc.Wayne
"Trying to shed my CASO ways"
They are pressed in. What should work: find a piece of round stock or heavy wall pipe that will just slip into the top of the tube. A large socket should work. Insert that in the top of the tube, to keep the tube from collapsing or being stretched beyound its elastic limit. Clamp a large pair of Vise Grips on the top of the tube, and tap on the underside of the Vise Grips with a small hammer. May leave some jaw marks on the tube, but it won't be crushed or distorted.Gord Richmond, within Weasel range of the Alberta Badlands
The only thing that worked on my 169 was turn the engine over, remove the oil pan and put a socket in the tube hole then beat on it with a BF hammer. It finally came out. It seems like some of those fill tubes were inserted with a light press fit and others with a HEAVY press fit.Rick
Kingman, AZ
Originally posted by wdills View PostRoy, I am referring to fill tube not the dip stick tube. nvonada,RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
