Window removal
  • Other: Window removal
    I'm having a block trying to figure out these back seat side windows on my 2 door hardtop Lark.
    there does not seem to be enough room to remove the window. I am stripping the car to go to body and paint. I got the front door windows out easily, but can't see how these back windows come out. Any help appreciated.
    Need to specify year. They're not all the same.
    Skip Lackie
      Is it a sedan or a hard top? If build like most cars if it's a hard top you roll them forward as you remove them, If a sedan most cars it either tips to the outside or inside as you lift them up.
        There is a pivot block at the door jamb with two bolts. Remove them to gain wiggle room. Remove the weather seal at the top first.
        Bez Auto Alchemy
          It's a 61 Lark VI Regal
            Early Larks(62 and earlier) had a padded upper bolster inside, and rollers under that. You have to remove the roller mechanism.
            Bez Auto Alchemy
