Champion larger intake valves?
  • Engine: Champion larger intake valves?
    A potential customer is asking about what can be done to muscle up the Champion. He remembers a Volkswagen intake valve had been used at some time in the past. Anyone have any recollections/recommendations.
    FWIW, there isn't a lot of space between the intake and a hard exhaust seat, so I'm not seeing great gains there.
    jack vines
    A bit of chamber releaving to create a nice big fuel passage...
      Anyone try a turbocharger?
      While my Champion 85 H.P. is no powerhouse, I'm not racing it, but just going for a nice ride, and it does that fine.
        How about a MILD grind on the cam? Most folks tend to go overboard, but a mild grind should help.
        60V-L6 - 60 Lark convertible
          When there is no more room for gains, turn the valve stems down a bit.
            Jack, I did a 55K six of a friends back in the 60's. I found my notes on what I did. I used a 1/8" over sized intake valve of 1 15/32". Ran a 70 degree piloted reamer down to make a 1.260" ID pocket. I cut the valve to 30 degrees. Used a Morgan H-1000 cam with 256 degrees duration and .378" lift. Also relived the block 5/32". Used a Morgan intake manifold and 2 Zenith ZOX9 carbs. Most of the hard parts I got from Morgan, so he probably had them made for his stock. Never asked as to what they were made for.
              Yes. A few on here. Most recent is Pop's Chariot. Also was it Sals54 had one going? Then there was the guy a few years back working on one in his 2R I believe. Good luck on the Search feature. Seems the Champion internals are tough enough, at least for a while.
              Cathcart gave up the effort, but people seemed to like his product. If he's still around, someone needs to get all his data from him.
              KURTRUK
                I don't know Bill Cathcart; having had one conversation with him. Several years back, a CASO called me about building a higher-performance Champion. At that time, BC was the only source of new aluminum heads, so I called him about getting one. Turns out, Cathcart had just spent way too much time on the phone with said CASO, so he recognized the details of the build RFQ and was less than patient. "I've spent fifty years learning how to do Champions right, gathering the parts and these guys want me to take the time to walk them through every step of it for free and then go buy most of the parts from someone else and build it in their garage!"
                Could be, he'd now feel free to be more forthcoming about parts and procedures, but it would take a good friend to go there.
                jack vines
                  idk if this will help, but i bookmarked it when i got the '51.
                  http://www.studebaker-info.org/Cathcart/bc.html
