Throttle Linkage
  • Engine: Throttle Linkage
    We are rebuilding the 289 engine in my '62 GT Hawk. What color should the throttle linkage between the accelerator and the carb be?
    Peter Bishop
    Director,
    Northeast Zone
    Natural metal, or, if rusty, 'aluminum' paint.
      I just looked a NOS one and would say they were cad-plated (dull silver) when new, so whatever you can use to recreate that look should be okay.
      Dan Peterson
      Montpelier, VT
      1960 Lark V-8 Convertible
        Cadmium plating isn't nearly as troublesome as chrome plating but, I've found a suitable cheap alternative. I bead blast the parts, then use a rattle can spray of cold zinc, available at any hardware store. Handle the parts carefully, as the cold zinc wipes off very easily. Then I spray with a clear coat. Once that's dry it's protected from corrosion and appears much like cadmium.
        '33 Rockne 10,
        '51 Commander Starlight,
        '56 Sky Hawk
          Is the cold zinc a paint color, or powdered zinc, or what exactly?
          60V-L6 - 60 Lark convertible
            Caswell sells a home plating kit called "Copy-Cad", which is actually a zinc plating, and works very well.
              It is a fine zinc powder (the can is heavy) in a volatile suspension. The medium evaporates quickly but does not adhere the zinc as a paint would. Hence the need for a clear coat. Though, as I google the product, there are brands that claim no additional coat is required. https://www.google.com/search?q=Cold...utf-8&oe=utf-8
              Being a CASO, I go with a simple cold zinc and a cheap clear coat. It passes muster in SDC judging.
              '33 Rockne 10,
              '56 Sky Hawk
                I've used a very light coat of Seymour Spra-Galv 16-845 Weld thru Primer which is a dull silver.
                  I just did mine with Rust-oleum aluminum engine enamel. Came out pretty good.
                  2005 Dodge Magnum
                  1952 Studebaker Land Cruiser
                    You can burnish the cold galv spray with a green dish scrubbie scotch-pad. (not to be confused with body shop 3m scotch pads). it ill put a little shine before clearing it. It makes it look more metallic, rather than grey.
                    Bez Auto Alchemy
                      Eastwood has spray on cadmium (look alike) coating.
