Celeron? Are You Kidding Me?
  • Engine: Celeron? Are You Kidding Me?
    Ok. So what's the deal with the Celeron camshaft gear on the '50 flatheads? I noticed in my "box of stuff" that came with the car, a cracked gear that had been removed. Any enlightenment on this curious non metal design feature would be appreciated. Thanks.
    1950 Champion
    1962 MGA
    Studebaker used them 'forever' in their engines, except for the later '56 up, HD & truck V8's, and the Avanti 'R' engines where an aluminum gear was used.
    Those celeron (fiber) gears have stood the test of time, usually lasting many, many years before failing!..Also, though not as strong as aluminum, they 'run' more quietly against the steel crankshaft gear!
      Every Studebaker I've ever owned had the celeron gear. Over the course of forty-nine years I have had to replace two.
      '33 Rockne 10,
      '51 Commander Starlight,
      '56 Sky Hawk
        Celeron was an early synthetic material, probably made .... before oil became the main building block of synthetics.
        Unfortunately, Intel named a processor Celeron some years back. A Google search of Celeron yields thousands of hits, but all concern the Intel processor, so it's difficult to research the material our gears are made from.
        60V-L6 - 60 Lark convertible
          I can say one thing in favor of the Celeron gears, they will outlast a Chrysler (MoPar) Cam Gear with Plastic coated Steel Teeth, about THREE to One!
            Or the same GM gear. Many a GM car has prematurely gone to the boneyard because the cam drive plastic failed and the whole front of the car has to be removed to replace it. Then many of the engines using the plastic crap are interference designs and the cam stops turning before the crankshaft stops and it bends valves on both banks of a V8.
            jack vines
              My Sister purchased a new 1970 Pontiac Catalina station wagon with the 400 CID V8. She had to replace the cam gear three times in the first 100K miles. So much for that plastic gear setup.
              Lt. Col. Jimmy Doolittle
                Just 'cause something is new doesn't mean that it will be better!
                That's why I'm content to remain in the simpler slow but reliable lane…
                  I hear You
                  Joseph R. Zeiger
                    My guess would be the "celeron" gears were phenolic resin (phenol-formaldhyde resin) based. The later stuff was probably filled nylon so I don't think one can do a direct comparison.
                    I don't recall a term celeron in this business but it goes back before me. Use Phenolic in the search term and it might help.
                    Bob
                      I have a Cloyes timing gear (fiber) that makes no mention of Celeron. Wasn't Celeron just a manufactures trade name.
                      American iron, real old school
                      With two tone paint, it sure is cool
                      Its got 8 cylinders and uses them all
                      With an overdrive that just won't stall
                      With a 4 barrel carb and dual exhausts
                      With 4.23 gears it can really get lost
                      Its got safety belts and I ain't scared
                      The brakes are good and the tires are fair.
                      Tried to sell her, but got no taker
                      I"ll just keep driving my Studebaker
                        Easiest google search would be for "fiber timing gears" everyone used them-even with chains. Material used varied, idea was the same, lower engine noise--till they broke, teeth sheered or pieces fell of and jammed up the works.
                          Celeron was a trade name for phenolic plastic, like Bakelite, but with a fiber filler. It's a composite material, just like carbon-fiber is today. In its day, it was hgh-tech. "Micarta" is another trade name for a similar products.
                            https://en.wikipedia.org/wiki/Micarta
                            https://en.wikipedia.org/wiki/Phenol_formaldehyde_resin
                            Heavy stuff for 1910.
                              If you want to do an Internet search, you'll get better results with "celoron". That's the true name.
