modern bulb part number - 47 Champ
  • Electrical: modern bulb part number - 47 Champ
    Does anyone know a part number for the parking light bulbs on a 47 Champion? They are very small. The SI catalog lists some bulbs I'm not sure about them. Has anyone ordered them?
    The 6V bulb number should be in your Owner's Manual. I suspect it should be Mazda No. 63, or, if it should include integrated turn signals, Mazda No. 1158.
      Are any of these bulbs made for 6 volt positive ground?
      My 1939 motorbike has a 6 volt positive ground generator, and LED would light up so much better on it.
        Thanks for the tip rockn10. Looks like it's a Mazda no. 55. Where do I find a cross reference for a part number like at NAPA or AutoZone?
          Just ask for a #55 bulb.
            My Guide lamp book only goes back to 1949. It shows the parking lamp bulb as #55 for the Champion, #63 for Commanders. The 1947's are probably the same. The #55 is indeed very small.
            American iron, real old school
            With two tone paint, it sure is cool
            Its got 8 cylinders and uses them all
            With an overdrive that just won't stall
            With a 4 barrel carb and dual exhausts
            With 4.23 gears it can really get lost
            Its got safety belts and I ain't scared
            The brakes are good and the tires are fair.
            Tried to sell her, but got no taker
            I"ll just keep driving my Studebaker
              Hi TWChamp
              Good old fashioned incandescent bulbs don't have any polarity, so as long as they have 6 volts on one side and ground on the other they will work.
              The modern LED lamps are a different story. They require a specific polarity i.e. a bulb that works with positive ground will not light up on a system that uses negative ground.
                Originally posted by ronnyb View Post
                Hi TWChamp
                Right, and that's why I was looking for these bulbs in LED 6 volts positive ground. Over the past week I've order several LED bulbs including some for positive ground systems. Some of them should work for the headlight and taillight of my 1939 motorbike, but I'm still looking for ones to fit 6 volt Studebakers.
                  55 is a very common bulb number. Commonly used in radios and 6 volt auto instrument panels.
                  Frank DuVal
                  50 Commander 4 door
                    Unfortunately old parts men aren't common anymore. We've had many people come on the Forum saying modern parts houses couldn't find or get a standard headlamp for Studebakers! If it ain't in their computer they don't know what to do.
                    KURTRUK
                      Crazy, especially when you consider that, until 1976 when the rectangular ones came in making it 7, there were only 4 headlight bulbs to choose from. All you need to know is how many headlights are on the front and if it's 6 or 12 volt. And they call themselves parts guys.
                        Ford part number: 78-13466 / Industry part number: 55 .. 6V single contact 2 candlepower bulb / Obsolete
                        CARPENTER NOS OBSOLETE PARTS in Concord NC has 31 = 800-476-9653.
                          I never would have guessed a number 55 bulb would be obsolete because lots of old radios also used them. I've always said that bulbs should be saved from junk cars before they go to the crusher. You just never know how quickly something can go obsolete, and become hard to find.
                            This Ford part number is obsolete, but I don't know if the bulb can still be bought at auto parts stores under its industry number.
                            Carpenter, besides selling obsolete parts, is the largest reproducer of Ford parts.
                              They are available at Advance Auto Parts. A 2 pack is about $5.00. I found them hanging in the rack in the aisle with the other bulbs. They also have other 6 volt bulbs, but you may need to know the bulb numbers as they do not cross reference to my M5 in the computer or online.
                              Common 6 volt bulb numbers are: Headlamp 4030, Parking 55, Stop 1158, Instrument 55. Check your owners manual or shop manual for your application.
Name:	Sylvania Long Life 55 LL Mini Bulb, 2 Pack 55LLBP2_ Advance Auto Parts.jpg
                              Bruce
