Is it necessary to dial indicate the belhousing on a Packard V8
  • Clutch / Torque Converter: Is it necessary to dial indicate the belhousing on a Packard V8
    I am in the midst of converting a '56 Golden Hawk from an Ultramatic transmission to a T85 3 speed w/overdrive. I know it is important if not mandatory to dial indicate the bellhousing to the engine when you change these on a Studebaker V8. Is the same true with a Packard V8. Thanks in advance.
    '62 GT Hawk (4 speed, A/C, Power steering - running and DRIVING!)
    I don't know the answer, but if I were doing it, I'd check it. If Packard had tooled up to maintain concentricy, you'd need a Packard OD bell housing.
      Thanks Tom. I do have a Packard V8 bell housing, flywheel, clutch, etc..
        Not necessary. The Packard bell housing has a flange which locates it.
        Make sure you have the flywheel re-surfaced, bolts, pressure plate, disc, fork, throw out bearing, return spring and pilot bearing in hand.
        I also prefer the Hurst floor shift conversion.
        Jack Vines
          Thanks very much Jack. This is for the car you just made the shifter bracket for.
            Nope, bell housing alignment is not needed. Also, if you need a t/o bearing, there is a common, available replacement that won't cost an arm and a leg. Its originally for a Toyota alternator IIRC. If you need the part number, I can dig it up for you. Do not listen to anyone who tells you it is unobtainium, so you must pay big $ for theirs.
              Thanks Joe. Part number please?
                Oops, I meant to say pilot bearing. Will dig that number up for you. I also replaced the t/o bearing with a modern bearing, but believe my car's t/o carrier had already been turned down about .050", so not sure the t/o bearing I used would work for you.
                  Here ya go. This is the pilot bearing. Still trying to decipher my maintenance log entry on the t/o bearing. Its the pilot bearing that is NLA. Every once in awhile, an NOS one turns up in the Packard world, and the seller usually wants a small fortune for it. http://www.ebay.com/itm/5-4712-NEW-S...VYLHmp&vxp=mtr
                    Many years ago when I did the change to od, I used a pilot large bushing for a 390 Ford. It fit the crank and the id was right for the T85 input shaft.
