Originally posted by WCP
View Post
Oil Leak/Road Draft Tube
Originally posted by StudeRich View PostHere is what a '63 looks like:
[ATTACH=CONFIG]59283[/ATTACH]
The Picture number 0102-22 is the Adapter to the Lifter Cover with a 3/8" Elbow welded on the side, that fits a 3/8" I.D. short PCV Hose to the PCV Valve, 2 more short Hoses and an 3/8" Elbow complete it to the base of the Carb.
0102-21 is the PCV Valve.
Originally posted by Kato View PostThis is the original engine so is there a way with the engine serial # to determine it's original set up? I bought the car with the finned valley and rocker covers and the rocker covers are not vented. I would assume the previous owner would have bought the finned covers that matched what was on the car originally but who knows!
The breather cap on the stack where you pour oil in may be the restricted type intended for use with PCV. Look inside, next to the spring clip that holds it in place. The restricted type has only two 3/16" holes to breath through; even though it has a full set of large holes around the rim. You may have to turn the clip to see the small holes up inside, if it's turned out of place.
With the restricted breather, a blow by tube, and no baffle in the valley cover; you might get oil blown out. There also should be a baffle in the oil fill stack, which just pushes in.
Mike M.Last edited by Mike; 10-27-2016, 04:09 AM.
Originally posted by karterfred88 View PostDo you have a production order for your car? Since you mentioned it's a full-flow with the spin on oil filter, either the production order or the engine serial number should give a good idea of the actual dates and then the parts book listings with special attention to the change notes might get you to the right combination.
Originally posted by Mike View PostThe breather cap on the stack where you pour oil in may be the restricted type intended for use with PCV. Look inside, next to the spring clip that holds it in place. The restricted type has only two 3/16" holes to breath through; even though it has a full set of large holes around the rim. You may have to turn the clip to see the small holes up inside, if it's turned out of place.
Mike M.
Originally posted by WCP View PostKato, I was referring to the "central stack". Your engine appears to be correct for a late model '62 V8, assuming that the stack hasn't been modified, as questioned in post #49 by Mike.
I started this thread last fall and I am just about to change the valley cover to an OEM cover to hopefully address this oil consumption issue. As mentioned by Mike in post #49 I have looked at the cap on my car and here is a pic of it.The parts manual shows a cap for 61S 61V 62S and 62V. As stated earlier my car came with the high flow 63 289 without any PCV, vented rocker covers and with a road draft tube. Is this the right cap for this configuration? On the parts list they show a cap for 63V and 64V and at the bottom of the page it says "not used sealed positive crankcase ventilation" So my car has a 63 style high flow 289 without positive crankcase ventilation so should I be using cap #1558193 or #1558580? Can anyone tell if I have the first or second one by the pic? Thanks.
Oil caps 2.pdf
Originally posted by Kato View PostOK thanks, that is what I thought but a previous post had me wondering.
So yesterday , i've removed my oïl breather tube with my oïl filter and clean all...oïl filter flexible....draft tube....but it was the same problem , no leaks when i start the engine but when i checked my oïl lever it was very low again....Today i check it again and now it's good.
Maybe 10w30 oïl is a solution...
Thanks for your Help
