'36 Ford, liquid comes out the tail pipe when cranked
  • '36 Ford, liquid comes out the tail pipe when cranked
    I have a 1936 Ford model 68 all stock. The engine cranks and run very good. It does not smoke running down the road. When it sits for a few days and is cranked, it blows what looks like a mixture of oil and gas out the tail pipe. What causes this and how can it be fixed?
    Sorry wrong site but can use any advise. GaryWA
      Yup. This one shoulda landed in Stove Huggers. Hard to speculate without knowing with some certainty what the fluid dripping out of the exhaust actually is.
      Whirling dervish of misinformation.
        I dunno, maybe leaking Carb. Needle and Seat letting excess Fuel in the Cylinders and washing Oil off?
          Blown head gasket. Water mixing with black carbon deposits in exhaust system looks oily.
          KURTRUK
            There is a device that fits in the rad. neck and samples fumes in rad. easy to use and can be borrowed at most FLAPS. Combustion Leak Detector i think its called. Luck Doofus
              It’s likely water condensed from combustion, having sat and picked up carbon along the pipe.
              After up and warm, place a cloth a few inches away from the pipe. If you don’t get much over a 5 minute idle, you’re likely fine.
                second what NCDave51 says. possible condensation.
                Are you losing any Coolant?
                  Try your question on the FordBarn forum: https://www.fordbarn.com/forum/
                  Dan Peterson
                  Montpelier, VT
                  1960 Lark V-8 Convertible
                    If it only lasts a minute or two, post #7 nailed it.
                    Wayne
                    "Trying to shed my CASO ways"
