Rotisserie
  • Rotisserie
    Any one have experience with Tuxedo CR 3000? It seems to be sold under several brands for varying prices. I was hoping to use this on the Speedster restore. When I did the Avanti, I just blasted on the lift. Had to power wash the shop and am still cleaning up.
    78 Avanti RQB 2792
    64 Avanti R1 R5408
    63 Avanti R1 R4551
    63 Avanti R1 R2281
    62 GT Hawk V15949
    56 GH 6032504
    56 GH 6032588
    55 Speedster 7160047
    55 Speedster 7165279
    That is the same style as we used on our 64 GT, it was easy to use once body was mounted. One person could rotate if needed but much easier with two. What I didn’t see was any bracing for door openings included. Guess a guy could fabricate them.
    It is an addiction!
      I just purchased one from pro lift. I included all the adapters, the door braces as well as the all terrain wheel kit. Hopefully, it will do the job. I will post pictures when it comes and I get body on it.
      78 Avanti RQB 2792
      64 Avanti R1 R5408
      63 Avanti R1 R4551
      63 Avanti R1 R2281
      62 GT Hawk V15949
      56 GH 6032504
      56 GH 6032588
        If you are inclined to build your own, here’s a pretty great set of plans I’ve had for years
        http://www.harwoodperformance.bizland.com/1941buick/
        Proud NON-CASO
        Romans 15:13
        Deuteronomy 31:6
        Proverbs 28:1
        Illegitimi non carborundum
          Thought about building one. However, when I started adding up cost of materials ... Additionally, while I am a fair welder, I am not sure I would trust my welds on heavy structural steel. In any case, the one I ordered is about $1,600 delivered to freight terminal near me. That price includes all attachments, door braces, and larger wheels (10") so I can easily move the assembly around. The larger wheels should allow me to use this as a body cart so I can transport to blaster and painter.
          The capacity is 3,000 lbs so I should be good as I estimate that a gutted 'K' shell weighs less than 1,000 lbs. It should be here soon so I can get back to work.
          78 Avanti RQB 2792
          64 Avanti R1 R5408
          63 Avanti R1 R4551
          63 Avanti R1 R2281
          62 GT Hawk V15949
          56 GH 6032504
          56 GH 6032588
            Picked up the rotisserie a couple days ago. It took 3 hours to assemble. As is usual for Chinese stuff, the instructions are abysmal. There are only a few pictures and words that describe the assembly process. Fortunately, they included a parts diagram. Unfortunately, the names of the parts did not match the scant instructions. However, by using the directions, the parts diagram, and a lot of intuition, I got it assembled. The only problem I had is that one of the mounting pads for the casters was off. A little work with a rat tail file took care of that . I will post pictures of the finished product when I can access a computer. I plan on mounting the frame tonight after it cools down
            I have no idea how to mount the body yet.
            78 Avanti RQB 2792
            64 Avanti R1 R5408
            63 Avanti R1 R4551
            63 Avanti R1 R2281
            62 GT Hawk V15949
            56 GH 6032504
            56 GH 6032588
