63 Wagon quarter panels
  • Wasjunk
    Looks good. I thought Kansas was a no rust state. But I know there is no such thing as a Studebaker with no rust.
  • COMMANDERPINK1
    Nice looking panel repairs and Wagon. I have a Kansas 63 Wagonaire I’m working on also when time allows.
  • ndynis
    Really nice job Dave! Great looking Wagonaire! Thanks for listing it on the Wagonaire Registry.
    Nick
  • Wasjunk
    Couple follow up pictures of quarters completed
    Originally posted by Wasjunk View Post
    Good thought but this is a fixed roof car and still pretty rusty. Every Studebaker from the midwest I have been involved with has had serious rust issues. I started working on them back in the mid 70s and they are only getting worse as time goes on. Poor older repairs are not helping the matters either. A lot of fiberglass and tar covering up the problems on this one whenI got it.
    Good point, I should have added that "Most West Coast or No-Salt States Fixed Roof 'Wagons' have little to No rust in the 1/4 Panels".
    I have seen a few and own one '64 Wagon without the problem, and I did attribute it to, NO Wagonaire Slider.
  • skyway
    StudeRich raises (as usual!) a good point; "do not drain the Sliding Roof drain hoses into the 1/4 Panels"
    An ancient Turning Wheels article suggested routing those slider drains to the outside, and I did it on the one I owned.
    FYI, there are 4 drains; 2 on each side.
    The 2 forward ones drain inside the B pillar & into the rocker, and of course the 2 rear ones drain into the rear quarters.
    Remove the upper & lower B pillar trim, and rear corner (painted metal I think?) covers, to access that drain hoses, & replace them with new tubing
    cut long enough to run outside the car.
    You can route the forward hoses out through the inside edge of the rocker at an opening just behind a body support.
    For the rears you have to drill a hole down low through the inner quarter.
    I had the hoses extended outside about an inch.
  • Wasjunk
    If anyone needs some, look for Parts Car FIXED Roof '63-'66 Wagons!
    They do not drain the Sliding Roof drain hoses into the 1/4 Panels and should survive.
  • Bullet
    If you made some up I am sure you would have people standing in line for them. Very nice!
    mark
  • Wasjunk
    I found one set but he is keeping for his own car. I respect that and moved forward.
  • studegary
    When I owned my 1963 Wagonaire, you could still buy NOS quarter panels. I guess that everything runs out eventually.
  • Wasjunk
    Thank you for the kind words
  • jwitt
    Nice job!
  • Wasjunk
    started a topic 63 Wagon quarter panels
    When there are no replacement quarter panels I guess you just build your own
