64 GT questions
  • 64 GT questions
    I need to know the following if possible
    1. proper original tire size/conversion to today's radials
    2. whitewall width
    3. color code for the cream/white wheel
    4. color code for the Bordeaux Red body color
    Thanks in advance!
    sigpicIt is an addiction!
    From my limited knowledge:
    1) Original 670/15 bias ply, modern 215/75R15 radials (wider than the originals, but about the same diameter). Note that the original 4.5"-wide rims are too narrow even for a 205/75R15 tire, let alone a 215.
    2) About 1"
    3) The easiest way to paint wheels is to buy either spray cans or a quart can of the off-white wheel paint from Studebaker International.
    4) I don't know this one. The mixers used in the original alkyd enamel aren't all available today, so one can't have the exact original paint color mixed. Usually, people pick a modern polyurethane paint color that matches and go with that. There are Stude fans who have already gone thru the books and picked the closest match in a modern paint, and I'm sure one of them will chime in with that info.
    -Dwight FitzSimons
    '64 Hawk R1 (Bordeaux Red), '64 Hawk (Astra White)
      Paint Code is P-6418
      Ditzler number 71418
      RM number 64S51R
      I don't have any DuPont numbers for 1964. I do have "most" of the paint chips from 1936-1965
      Jim
      their Memorials!
        Bordeaux Red in DuPont Centari.
        First time I did it (spring of 1991) it was a fleet color for England Trucking (remember their dark red over the road tractors?).
        Second time (I was doing a repair in August 2005) it was a Ford color.
        Both times the same recipe, #97095A H
          As usual, Joe, the same recommendation: P195/75R15 if you have 4.5" wide wheels. P205/75R15 if you have 5" wheels.
          The circumference of either will vary by brand, often quite a bit. The Coker Tire catalog, available on line, has all the information you'd ever need about both varieties, stock and radial. BP
          Ayn Rand:
