A Nice Triple Power Outlet with a USB Port for Only $2
  • A Nice Triple Power Outlet with a USB Port for Only $2
    I have Model A's and Studebakers, all with 6 volts positive ground. I recently bought this outlet for only $2 on ebay, with free shipping. The triple outlet with USB port comes in a nice insulated plastic case, so it can be mounted to metal with no worry about shorting due to the car having positive ground. Just connect the positive to the center contact on the plug, and negative to the side contacts. Note that only one side contact is wired, so be sure to use the correct one if you clip on the power or solder a wire to it. The USB port will run a dash cam or charge a cell phone. My GPS works fine on 6 volts.
    http://www.ebay.com/itm/281840953203...%3AMEBIDX%3AIT
