The last car I painted in lacquer was my 66 Daytona. I had sanded it down to the factory primer the painted it & used slightly over 3 quarts for the complete job. Two years later it started to check. Before when you had lacquer checking it was from too thick of a base, so that with expansion & contraction you would see cracks or checking, also commonly called "crows feet". I knew that wasn't the cause on the Daytona so the only conclusion I could see is how lacquer was made, in this case 1989. With all the regulations being enforced I figured the paint companies, in this case R-M, was formulating the paint trying to comply & causing the paint to fail much sooner than before.
I painted my #1 Avanti in august 1994 in a 2 stage, urethane paint by PPG. Today it still looks new. Yes there are a couple chips here & there & last week I noticed a crack on the top of the right quarter but if I had to do it again I would use the same material.
Another case was the last Studebaker made, the 66 Cruiser. When I saw it in 93 I couldn't believe how bad the paint looked. It sure didn't look as good as the last South Bend car. Dull & very orange peeled. No wonder it was redone a few years ago. I sure wouldn't want any of my cars that I've painted look that "original".
