'54 Starliner H/T: Overall Dimensions and Weight?
  • '54 Starliner H/T: Overall Dimensions and Weight?
    I'm certain someone out there can point me to a source for the physical dimensions and weight of the '54 Starliner Hardtop Coupe. I need to know if the one I'm looking at will fit into my garage with my '63 Avanti under it - on a four post lift, of course.
    Is there a handy place I can go to get that info? Thanks, all.
    A quick Google search found this:
    http://classiccardatabase.com/specs....53&model=29300
    Pat Dilling
    Olivehurst, CA
      Some times those old charts put out by Stude for shipping purposes are not right. Dimension wise yes, but not weight. Figure a 53 to 55K to weigh between 3,400 and 3,500 lbs. in street trim.
        You do not state if the '54 Starliner is a Commander or Champion. The length will be the same, but the weights will be quite different.
          You are correct. Champion Starliner, 6 cylinder with three-speed transmission.
            Still going to weigh over 3,300 lbs.
              The dry shipment weight is 2825 pounds. Options and liquids will add to this.
                Originally posted by Pat Dilling View Post
                Pretty impressive webpage, until I looked up my '63 Avanti and discovered (!) it has "4 wheel hydraulic drum brakes". Now I'm a little concerned about its accuracy.
