Hello, and thank you for accepting me to this great forum! I have a chance to purchase what I believe is a 1959 Scotsman pickup. It is in pretty good shape except for extensive rust to the step plate and seat riser area. And, unfortunately, the serial number has went by the wayside with the rust. I am a welder fabricator by trade, so the rust doesn't bother me, as I know I can repair the rusted area. My question is: Is there any other location with a serial # stamped on this truck, maybe to the frame? Just wondering if would be a waste of my time pursuing it any further. The truck has been sitting for 30 years, left at this location by a previous owner, and the current owner knows nothing about it. Thanks in advance for your input.
1959 Scotsman, I think?
The Serial Number plate should be affixed to the driver seat riser, right below the driver's left thigh. It should be visible by opening the door and looking straight in against the side of the seat frame.
Yes, it is a Scotsman pickup.BP
Ayn Rand: "You can avoid reality, but you cannot avoid the consequences of avoiding reality."
Originally posted by BobPalma View PostThe Serial Number plate should be affixed to the driver seat riser, right below the driver's left thigh. It should be visible by opening the door and looking straight in against the side of the seat frame.
Do pickup trucks have that secret serial number stamped in the rearmost cross member like the car line?sigpic1957 Packard Clipper Country Sedan
Lt. Col. Jimmy Doolittle
There's a lot of bondo on that right fender. You say the seat riser is missing... completely?? Gosh, if the truck is that rusty, it might be a good one to avoid. On the other hand, the outside looks pretty good. Was the seat riser perhaps cut away for some reason?Home of the famous Mr. Ed!
Ron Smith
They DO NOT have a Second Serial Number Location! You are pretty much screwed!
In most States the hard way is to re-register it without a Title until enough time has passed for the owner to claim it, and then you can get the Title.
Sometimes they will give you a State registered VIN # sticker to re-serialize it.
I believe in Calif. it is as easy as sending a letter/Form to the last registered address with a return receipt of delivery, if it comes back, you take those papers to the DMV.
And then there are the Title re-creators in other States, that for enough $ can do anything!
Best to check with your GA Dept. of Licensing.StudeRich
If you're new to Studebakers, look what's available in replacement sheetmetal for that truck: http://www.classicent.com/studebaker/pickups/c-cab
I'm sure there's solutions to lack of a serial number.KURTRUK
Originally posted by StanwoodThis has probably been beaten to death at some time on the Forum, but are we totally dismissing the idea that ANY trucks ever had a secret serial number? Please see my post #6.
We are not aware of any Trucks in that category with a Frame Serial Number.StudeRich
I really appreciate all of your comments and suggestions, I think I am going to get the truck anyway. I know I can get it registered, was hoping to keep original with serial # since it looks like they are not many of these trucks of this year around. How many are known to exist today? Anyway, still worth 500 bucks.
There are still a number of complete NOS truck floor pans floating around -- I just sold one this year. If you're an accomplished welder, the replacement of the whole floor assembly might be easier than attaching patch panels. Second, it's pretty much the consensus of the truck folks that there is no secret serial number stamped on Stude trucks. I sandblasted the entire frame of my 54 3R6 two years ago and found nothing except for some (presumably) Budd part numbers on the top of a couple of the middle cross members -- nothing else. I have also done the same with several truck radiator saddles and found no numbers of any kind.Skip Lackie
I have a '57 Transtar. When I had the engine out and front nose off, I found the serial number stamped into the frame. I do not remember where on the frame just that I found it when striping and painting the front of the frame. Do not know if this is true for all C-cabs but it wouldn't hurt to look!
Originally posted by rkapteyn View PostThere should be a body tag under the hood on the passenger side on the firewall.
Robert KapteynLast edited by Skip Lackie; 11-26-2014, 06:32 AM.Skip Lackie
