In need of a tachometer
  • In need of a tachometer
    For a GT Hawk. tach, bezel and mounting bracket. Please, thank you chers jimmijim
    bump 1234567890-
      I've got most of one somewhere, but am not sure if it's working. Do you have a sender? The one I have is the small brick solid state which has 6cy and 8 cyl posts.
      jack vines
        Private message sent
        paul
          bump234567890
            The retainer rings are same as for speedo and clocks, and turn up at most meets for $10-20 each. Less than a year ago, Tom K. had plenty of them for $15, but they were driver quality. If nothing else, SI has them for $45 each (part #1555431).
            The mount bracket in the back may be harder to find, especially when looking for one, but I likely have one out in the garage. The OEM tachs are pathetic, when it comes to accuracy. I swapped mine out for a $60 Stewart Warner on feebay that looks close enough for me, and is much more accurate. I have the old OEM tach, but it's inaccuracy is unacceptable to me. I also have the rectangular sender, if I did not toss it.
            You will also need a Lilliputian or two to install it (unless you remove the speedo to access it)
