Exhaust tips
  • Exhaust tips
    I have those period correct exhaust deflectors on my Sky Hawk, and it seems like one always has a carbon deposit on it while the other doesn't. Thoughts?
    peter lee
    Before going further, I'd check my heat riser, if stuck could be causing all (most) exhaust to go out the right side.
      Yep! Do check the heat riser. I just freed up the heat riser on my 57 Packard.
      Froze shut.
      Lt. Col. Jimmy Doolittle
        The heat riser is located on the right hand (passengers) side exhaust manifold. If the counter weight is up then it's stuck closed. It needs to either be free to turn or keep it stuck open so the counterweight is down.
        60 Lark convertible V-8 auto
        61 Champ 1/2 ton 4 speed
        62 Champ 3/4 ton auto
        63 G.T. Hawk R-2,4 speed
        63 Avanti (2) R-1 auto
        64 Zip Van
        66 Cruiser V-8 auto
          What warren said, and when closed it goes out the LEFT side.
            I think a cable operated heat riser would be a good thing.
              Is this something I can do myself? My mechanic is VERY expensive.
              peter lee
