1964 Champs - T-Cabs - 8Es - forum registry
  • jts359
    I got some nice nos interior stuff from Will at Starlight Interior , He had some in different colors as they are same as Larks , Ed
  • 62champ
    Originally posted by 259Champ View Post
    64 Champ E5139484
    Ove the winter I will be pulling out the interior and fixing a bunch of problems with wiring and non-functioning items . Also replacing the old dirty carpet and freshening up the interior and fixing the weatherstripping an
    FYI - Studebaker International had a three foot deep pallet sized crate full of NOS 8E5 main wiring harnesses - easy to replace the whole thing instead of chasing gremlins... Thanks for the info.
  • 259Champ
    64 Champ E5139484
    I bought this truck in late 2018 after it had been sitting under a shed roof for about 4-5 years . I had serviced it intermittently for the previous owner over the years , just doing the bare minimum to keep it running , never wanting to spend the effort to make it safe and reliable .
    I spent 2019 going over the mechanicals , brakes gone through and M/cyl upgraded , carb overhaul , fuel tank removed and cleaned of the 20lbs of rust in it , new tires to replace the dry rotted ones on it , clean the mice out of the glove box and exhaust , buff out the inch of dust on the paint , tune-up and adjustments , fluids and filters , radiator recore and everything else to make it safe and reliable . Also I took off the poorly installed A/C and power steering and returned it to manual steering . Hoping to make the A/C functional again soon .
    In 2020 , from April it has been my daily driver to work and I have been adding some dress-up under the hood . New exhaust will be going on soon and I am chasing rattles and noises .
  • lark63
    I now own the 1964 champ owned by Brad Kuchan in Illinois, I will get the actual numbers to confirm soon
  • flathead
    a few upgrades since I purchased the truck: Vintage Air Slimline under dash unit, 64 GT Hawk push button radio with FM conversion, Jim Turner Disc Brake conversion, Full application of LINEX in bed Click image for larger version
ID:	1837079 , replaced the 4:10 ring & pinion with a 3:54 set (which is as low as you can go in a DANA 60) Click image for larger version
  • flathead
    a few upgrades since I purchased the truck: Vintage Air Slimline under dash unit, 64 GT Hawk push button radio with FM conversion, Jim Turner Disc Brake conversion, Full application of LINEX in be, replaced the 4:10 ring & pinion with a 3:54 set (which is as low as you can go in a DANA 60) Click image for larger version
  • 62champ
    Found it! E12-6769 is on Post 58 of Pg. 2.
    Wow that's a LOT of scanning!
    If you look at the first post, the VIN numbers are hotlinks to the actual vehicle within all the pages - no searching involved.
    Wow that's a LOT of scanning! Some of these 8E Trucks have a REALLY large number of Pics, mostly the junky ones.
    So this verifies what we thought that this Nice Orange 3/4 Ton with the Cloverleaf stamped Engine Block, is or Was for sure a 6E Heavy Duty 289! 6EJ312 was Assembled Sept. 12, 1963.
    That is, If any of the Roto Cap Valve Rotators, Special Valve Springs, Aluminum Cam Gear and Tri-Metal Clevite 77 Bearings are still in there or replaced after the rebuild.
  • flathead
    I would like to update the 64 registry for E 12 6769. the current link shows the photos from George Shirley before I bought the truck from him. here is a pic of the serial number pad from the 289 that is in the truck now. thanks, Mike Schmitt
  • Studebaker Wheel
    In case anyone is interested. Reproduction 2 X 3 foot. Click image for larger version
Name:	IMG_5279 email.jpg
  • 62champ
    8E12-6750 - 122 WB - T6 cab - for sale on Craigslist, July 2019.
    Radio, AC, OD tranny
    Information from ad: A 1964 Studebaker Champ Truck, V-8 (289 engine), 3 speed with overdrive, air conditioning, sliding cab window, camper shell. Good condition, good interior, runs. Some body rust. Original instrument panel, radio, engine. Asking $7,000 or OBO. No trades.
  • 62champ
    8E5-139204 - 112 WB - unknown cab - partially restored - awaiting completion - located in Belton, Texas.
    Unknown accessories.
  • thom
    I wish I had a '64 Champ to add to the list. A white, six cylinder, no-overdrive, three speed...
  • 62champ
    8E7-21729 - 122 WB - T6 cab - for sale on Facebook Marketplace, June 2019.
    Climitizer, four speed, lighter, radio
    Originally posted by AceGikmo;
    [ATTACH=CONFIG
    81273[/ATTACH]
    /Cut/The carburetor, rebuilt. The linkage doesn't look quite right to me. I haven't tried to start it yet. It was missing a thermostat housing. I was able to buy another carb from eBay and took the best parts of each. There was no fitting between the thermostatic choke and the breather to the valve cover, so I epoxied a tube into a bolt./Cut/
    Welcome to the SDC and to SDC Forum Ace! Glad to see ANOTHER New Washingtonian here!
    You REALLY got me confused on this one!
    The Thermostatic Choke Cover has a small tube that goes into another tube in the Center Heat/Exhaust Crossover Port of the Intake Manifold and looped back out, just to gather HEAT for the Automatic Choke.
    None of this would be connected to or have anything to do with a "Valve Cover".
    Of course all of this is on the Right Side of the Carb. so I can't see any of what you are talking about.
    The Crankcase Breather system would be a PCV Valve connected by rubber Hose to the Tube coming out of the Back of the Carb. Base and connecting on it's other end to the rear of the Lifter Cover.
    All of the Parts you describe and show look correct for a '64 V8, including that Stromberg Model WW 6-132 which IS a 1964 Carb.
    We do not know of any last minute substitutions, parts shortages or mixed parts on ANY of the Last South Bend Studebaker Cars or Trucks.
    All of the Correct Parts are very well called out and illustrated VERY well in the Studebaker 7E to 8E ('62-'64) Truck Parts Catalog.
Name:	63 Champ3.jpg
ID:	1728180 < Here is a '63 or '64 Champ "T" Cab Pickup. (it enlarges 2 more times)
    That curled Tube is the correct Choke Heater Tube going into the Intake Manifold.
    NOTE: please pay NO attention to that Upper "Hot" Water Inlet Hose going to the Climatizer Heater Core, it is SUPPOSED to go to the Control VALVE to control the Temp. but this one is incorrectly routed to the Core, so it cannot be turned OFF and is running backwards.
