1964 Champs - T-Cabs - 8Es - forum registry
  • #46
    Hi, I'll add my 1964 Champ to the registry.
    Owner: Robert
    I bought this truck from a nice man in Lubbock, Texas in Nov. 2016. I paid a transporter to deliver it.
    1964 Studebaker Champ---V8 engine w/factory dual exhaust---factory 4 speed floor manual shifter (?)---long box/8.5 ft.
    odometer stopped at about 63,500 mi.---engine looks untouched---all original glass---inside cab truck is very nice, original naugahyde (?) bench seat and headliner are both in very nice original condition--- radio is original---sat under a carport for about 11 yrs before I got it---tires are rotten--totally inoperable right now--all original powertrain components---driver door latch is bad, must shut real hard---has serious rust in passenger door bottom and 1/4 panel---prior owner's uncle did a DIY replacement of rusted floorboard pans---there is surface rust about the truck---underneath looks a lot better than the truck's body does---I pray no real bad issues underneath---I think the engine is a 259 cu in w/maybe a single barrel---it is a sort of tan mixed with rust color outside---the bed was painted a medium green(?)---previous owner drove it 2-3 yrs while going to Jr College in Lubbock, then I think he got a newer vehicle---he said it coughs when starter fluid is sprayed in it. Tomorrow a local mechanic is supposed to come take a look if weather calms down . My goal is to get it running, stopping, and braking like a truck should. I plan to work on rust myself, and cut worst out, and study videos about body filler. I do not want it to look pretty, it looks so awesome now, sometimes I just go and look at it. My plumber loves it, he was here to fix water heater and his Dad was a Studebaker guy, he even loved the 8.5 foot bed ( only a plumber could do that right ). The VIN number is: E721420. Last, I guess I'll need to install seat belts once I get it running.
    • #47
      Your truck probably has a 2 barrell carb. Do post pictures when you can.
      • #48
        Hi Robert, Welcome to the SDC and to the SDC Forum!
        The Stromberg Model WW 6-132, 2 Barrel Carb. does not mean it is a 259, either a 259 or a 289 would have the very SAME Carb. unless ordered with a 4 Barrel.
        Check the Engine number STAMPED into the Machined flat, Pad on driver's side of the Front Corner, on Top of the Block.
        3E = a Standard 259.
        5E = H.D. 259
        6E = H.D. 289
        7E = Std. 289
        I know it's a Wacky sequence, with NO "4" and the Heavy Duty 289 ahead of the Standard one, but THAT is how they were Numbered/Identified.
        The numbers following those are just the Engine build sequence.
        • #49
          Thank you StudeRich.
          - - - Updated - - -
          Thank you, will try to get some pictures.
          • #50
            8E7-21880 - 122 WB - T6 cab - for sale on Ebay, March 2017
            Climitizer, spotlight
            • #51
              8E5-139408 - 112 WB - T6 cab - for sale on Ebay, April 2017
              V8 transplant, four speed, radio, and climitizer.
              • #52
                8E7-21889 - 122 WB - T6 cab - for sale on Craigslist, May 2017
                Ad states it is a 289 V8, radio, climitizer
                • #53
                  8E7-22249 - 112 WB - T6 cab - photos from the 53rd International Meet in South Bend, Indiana, May 2017.
                  Ordered from factory with 16 inch wheels, twin traction, heavy duty front and rear spring, four speed transmission, and 4.27 rear. Shipped to Wyoming. Restored by Ross Ball of Lorena, Texas back in the early 1990s. Ross updated the interior and did some engine modifications to make it more modern.
                  • #54
                    8E7-21577 - 122 WB - T6 cab - for sale on Ebay, August 2017
                    Radio, climitizer, factory rear bumper, appears to have been Parchment white originally.
                    • #55
                      8E12-6904 - 122 WB - T6 cab - in wrecking yard in south eastern Pennsylvania
                      Climitizer, direct reading gauges, four barrel carb., 5th OD transmission, factory AC, power brakes - by VIN number, this is the very last E12 produced by Studebaker.
                      • #56
                        8E5-139162 - 112 WB - T4 cab - for sale on Craigslist, September 2017
                        climitizer, converted to non-Studebaker V8 and automatic.
                        • #57
                          8E-7 112 wb...#21473...........engine replaced w/rebuilt 1957 289, 2 barrel carb, 3 speed o/dClick image for larger version
ID:	1716621Click image for larger version
ID:	1716622Click image for larger version
ID:	1716623Click image for larger version
ID:	1716624Click image for larger version
                          • #58
                            8E12-6769 - 122 WB - T6 cab - for sale on Ebay, January 2018
                            4 speed, (info from the owner: CLOVER LEAF ENGINEBORED 30 OVER WITH NEW PISTONS/ NEW CAM 4 SPEED TRANS/ NEW CLUTCH AND PRESSURE PLATE, FLYWHEEL RE SURFACED,DANA 60 TWIN TRAC/ 4:10 GEARS/ 5 NEW TIRES/ BRAKES ON ALL 4 CORNERS WITH A MUSTANG BRAKE BOOSTER, NEW WIPER MOTOR/ ORIGINAL SEAT AND DOOR PANELS/ HAVE NEW KING PIN SET BUT NOT INSTALLED/ NEW HEADLINER BUT NOT INSTALLED/ HEADS MODERNIZED /R1 INTAKE WITH 600 EDELBROCK CARB WITH ELECTRIC CHOKE/ NEW TINTED DOOR GLASS AND REAR WINDOW/ FRONT AND REAR WINDOW RUBBERS/ HALOGEN HEADLIGHTS)
                            • #59
                              8E7-21694 Champ was bought and brought east to Pittsburgh, where it is being rebuilt and painted. Click image for larger version
Name:	64 Champ dashboard.jpg
ID:	1719614Click image for larger version
Name:	64 Champ shift pattern.jpg
ID:	1719615Click image for larger version
Name:	64 Champ engine.jpg
ID:	1719616Click image for larger version
Name:	64 Champ tailgate repainted.jpg
                              • #60
                                Thanks landriopa for the two trucks added to the forum - might be the most by someone other than myself in a couple years...
                                And it looks like this 8E7 was already on the list....
                                http://forum.studebakerdriversclub.c...68#post1000868
