OD solinoid needed
  • OD solinoid needed
    The late 3 terminal job and a source for a good wiring diagram.
    JDP/Maryland
    64 R2 GT cost to date
    $60,222.25
    63 GT Hawk
    63 Lark 2 door
    59 Scotsman
    54 Starlight
    52 Starliner
    51 Commander
    39 Coupe express
    39 Coupe express (rod)
    JDP Maryland
    http://www.ncsdc.com/TechnicalPages/.../Overdrive.htm
    Bellingham, WA
      Bellingham, WA
        Thanks, but I need the later diagram for cars without the relay.
        JDP/Maryland
        $60,222.25
        63 GT Hawk
        63 Lark 2 door
        59 Scotsman
        54 Starlight
        52 Starliner
        51 Commander
        39 Coupe express
        JDP Maryland
          JDP/Maryland
          $60,222.25
          63 GT Hawk
          63 Lark 2 door
          59 Scotsman
          54 Starlight
          52 Starliner
          51 Commander
          39 Coupe express
          JDP Maryland
            JP - When I was scratching my head over my new trans with OD, Mr. Biggs sent me this message. No diagram, but I think it is self-explanatory - I figured it out and it works perfectly. This is for the later 3-terminal solenoid, no relay (12V).
            Quote!
            The reverse lockout switch is really not necessary so long as you're setting the OD up to work as it should. In fact, that's why the lockout Sw was done away with after 1955 - someone realized it was unlikely you'd ever find yourself going fast enough for the OD to engage when you were backing up!
            As Tom says, you can just leave the switch in place to fill it's hole and simply wire from the governor to the #4 terminal (this was a green wire if you wanna stay with the factory colors - 18gage will do). In other words - the switch still in place, but with NO wires attached to it!
            The #8 terminal of the Sol gets a 14 or 12 gage wire (red, if you wanna use the right colors)that goes to one of the two terminals that are closest to the plunger on the kickdown switch. The OTHER terminal of the KD Sw that's closest to the plunger gets wired (14 or 12 gage red wire again) to a 14amp inline fuse and the fuse is fed directly off the battery side of the starter solenoid.
            The #6 terminal of the OD solenoid gets a black wire to one of the terminals farthest from the KD Switch's plunger and then a black wire goes from the opposite side terminal (farthest from the switch's plunger) to the + terminal of the Ign coil.
            Wired like this - OD control cable installed right, and you're good to go!
            Unquote!
            Hope this helps, and thanks again to Mr. Biggs!
            Las Vegas, NV
              Quote!
              Unquote!
              Las Vegas, NV
                Thanks, I found that post too, guess we need a solenoid.
                JDP/Maryland
                $60,222.25
                63 GT Hawk
                63 Lark 2 door
                59 Scotsman
                54 Starlight
                52 Starliner
                51 Commander
                39 Coupe express
                JDP Maryland
                  JDP/Maryland
                  $60,222.25
                  63 GT Hawk
                  63 Lark 2 door
                  59 Scotsman
                  54 Starlight
                  52 Starliner
                  51 Commander
                  39 Coupe express
                  JDP Maryland
                    I'll look at my stash tomorrow. I might well have one.
                    Miscreant adrift in
                    the BerStuda Triangle
                      Miscreant adrift in
                        Thanks Bob, I'd rather not have to buy a NOS one.
                        JDP/Maryland
                        $60,222.25
                        63 GT Hawk
                        63 Lark 2 door
                        59 Scotsman
                        54 Starlight
                        52 Starliner
                        51 Commander
                        39 Coupe express
                        JDP Maryland
                          JDP/Maryland
                          $60,222.25
                          63 GT Hawk
                          63 Lark 2 door
                          59 Scotsman
                          54 Starlight
                          52 Starliner
                          51 Commander
                          39 Coupe express
                          JDP Maryland
