R1 Carb Filter
  • R1 Carb Filter
    Anyone have the dimensions for the cartridge for the chrome R 1 air filter?
    I don't have the dimensions but when I owned a '63 R1, it used the same air filter element as my '64 Pontiac Bonneville 389 4-barrel.
      Thanks , but that's not good enough for my local FLAP store . I also was told that a Ford 289 HP filter is the same but they told me they need measurements in order to match me up .
        I can measure one in the shop when I get home tonight, if you don't do better fore then.
          Old stock # Purolator AFP-80
          2 3/16 Height 13 1/4 Diameter Filter material about 1 inch thick
          That is as close as I can measure the filter
          Ron
            Really, is it so hard for them to just look up a Police Interceptor 406 '64 Ford or one of MANY Hi-Performance Fords using that Element?
              Ron
              Thanks guys ....Appreciated !
                Yes, it is.....that is ALSO 50 years old. Most FLAPS don't and won't want to list anything other than what sells well.
                It's a fact of life, if you are in the old car business, then you HAVE to be YOUR OWN PARTS PERSON . In other words it's up to you to research what fits and doesn't fit, AND THE CURRENT PART NUMBERS.
                If you find a parts store wiling to look in books, and cross references for you, then you are in the MINORITY.
                Bez Auto Alchemy
                  The K&N E-1560 is supposed to be a direct fit for the R-1 air cleaner
                  Butler, PA
                  63 Avanti R1 R2899
                    WIX 42063, NAPA 2063, or Fram CA-114 also work.
                    Or if you do a search on the forum you get this link..
                    http://forum.studebakerdriversclub.c...il-change-time!
