If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You will have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
Bad News Gang, The transmission seized yesterday. I put it in reverse, heard some weird grinding noises, then a loud clank and she stopped dead in her tracks.....
Mabel 1949 Champion
1957 Silverhawk
1955 Champion 4Dr.Regal
Gus 1958 Transtar
1955 President State
Fresno,Ca
Mabel 1949 Champion
Hawk 1957 Silverhawk
Gus 1958 Transtar
The Prez 1955 President State
Blu 1957 Golden Hawk
Fresno,Ca
Mabel 1949 Champion
1957 Silverhawk
Gus 1958 Transtar
Fresno,Ca
Mabel 1949 Champion
Gus 1958 Transtar
Fresno,Ca
D'OH!![B)][xx(]
<h5>Mark
'57 Transtar
3E-6/7-122 </h5>
Mark Hayden '66 Commander Zone Coordinator Pacific Can-Am Zone
D'OH!![B)][xx(]
<h5>Mark
'57 Transtar
3E-6/7-122 </h5>
Sorry to hear that. [xx(]Is it possibly the flex plate? What are the symptoms? Does the engine seeem to freewheel? Is the transmission locked? There are some great trouble shooters on here.
Rob
Rob
There was a loud clank/bang that came from the middle of the hump. rear wheels locked up and engine shut down. I could not crank the engine or roll the car. I disconnected the flexplate bolts and the engine turns freely. I cannot push the car forwards or backwards and there is tranny fluid coming from the side of the case. I think its safe to say the tranny is toast. I'm not totally surprised after all the warnings I heard about this transmission coupled with the fact that when the machine shop reworked the engine, they said barnacles were hanging off the crank shaft. The car was sitting in oceanside CA for a few years. So, I guess a new tranny is in order (probably rear end too). I bid on the 64 on ebay to snatch its interior and a few other parts to finish Lucy. Its a 3 speed o/d. I may change Lucy over to manual tranny. If the commander has solid enough floors, I may pull Lucy's engine and see if I can make it run a while. I have all the brake stuff that needs to be installed on Lucy and its the same as the commander.
Well since you have the 3 speed OD stuff on hand now, with everything you would need to do the swap, I'd say swap the auto for the manual. It will be a lot "peppier" that than automatic, and will save gas mileage as well.
Matthew Burnette
'59 Scotsman
'63 Daytona
Hazlehurst, GA
