If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You will have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
I did on one of mine but that was back in 94 when I painted it. Memory isn't that good but I don't remember anything out of the ordinary although I guess when I reinstalled the cylinders I put them in with the teeth of the key facing up (as is the usual way) but Avanti's have them facing down.
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
I just did this recently. You need to "Open" the door handle, and then put something in the open space you'll see, to hold it "open".
Now you can look for the release hole on the lock cylinder. I used a paper clip inserted in the release hole to free the cylinder. With the key in the lock, the cylinder will move outward ever so slightly when it is released...........then you can pull it the rest of the way out.
John
