52 rear stabilizer bar
  • 52 rear stabilizer bar
    When I opened the trunk of my "new" 52 I found this rear stabilizer bar. I am guessing (hoping) that it is off of a 51-52 Y body. The picture in the parts book looks similar, but it's hard to compare. Anyone have a picture of one of these actually hooked up, maybe on a frame in restoration?
    Say, didn't someone recently post a nice pic of one (for sale?) out and on the ground?
    Seems like it was within the last week or so. I'd search for that, 'cuz this is the best I can do~
    The pic above is my '58 Packard sedan, by the way.
    StudeDave '57
    StudeDave '57
    US Navy (retired)
    SDC Member since 1985
    past President
    Whatcom County Chapter SDC
    San Diego Chapter SDC
    past Vice President
    North Florida Chapter SDC
      Thanks, what you posted is not the whole answer, but it helps. I've never worked on a Studebaker that had one of these installed so how it fits is a bit fuzzy.
        Between the parts book and the repair manual maybe there is a better picture then mine.
        But I'm glad I was able to help at least a little bit.
        StudeDave '57
        StudeDave '57
        US Navy (retired)
        past President
        past Vice President
          I posted one off a 53 recently. Don't know if it's the same. My parts book is in the shop and I just got home from work with a backache. So I will look later. I am sure someone has one right by the computer. LOL Anyway, here ya go with a 53:
            StudeDave '57
            Dave, I believe the '53-up rear bar, like the one on Your '58 Packard, is a different animal than the '51-'52 version.
              I can post several pictures from different angles for a 53, so if it's the same hollar
                The 53-54 is a different part number, but I would like to see how it mounts.
                  Howard,
                    Originally posted by Charlie D View Post
                    Howard,
                    Charlie D.[ATTACH=CONFIG]32717[/ATTACH][ATTACH=CONFIG]32718[/ATTACH][ATTACH=CONFIG]32719[/ATTACH][ATTACH=CONFIG]32720[/ATTACH]
                    Thanks Charlie. The shape looks about the same, but the 52 version may be narrower just like the rear end. Nice clear pictures of how yours mounts.
                      That's the one I was thinking of!!! Nice.
                      In what way?
                      Is it mounted differently, or...?
                      StudeDave '57
                      StudeDave '57
                      US Navy (retired)
                      past President
                      past Vice President
                        In what way?
                        StudeDave '57
                        Although it's very similar,...I believe it's shaped differently for body clearance reasons.
                          Okay, so now we know it is likely more narrow, and 'maybe' shaped differently.
                          I'll go with that.
                          But does it mount differently?
                          How it's mounted is also what was asked, and that's what I was trying to show.
                          Now a much better picture has been posted. (albeit on a '55)
                          StudeDave '57
                          StudeDave '57
                          US Navy (retired)
                          past President
                          past Vice President
                            The main bar mounts/swivels on the frame, where the frame kicks up, ahead of the differential. There are already four mounting holes for it in the edge of the frame.
                            The arms attach to the plates that hold the rear springs and shock absorbers to the axle.
                            The shape and curve of the connecting arms, as well as the width of the main bar are different, with 51-53 being narrower than 53-up. You can think of it this way:
                            -51-52 is one set and
                            -53 and newer is the other set.
                            -Some 50 Commanders had them as well, but that would be a third set.
                            None are interchangeable even though they look similar.
                            They all mount the same way.
                            60V-L6 - 60 Lark convertible
                              Thanks Roy. Good information for those searching later too.
