ID plate
  • ID plate
    Hi everyone
    A friend bought a custom 37 coupe a year or two ago. He is curious as to what the ID plates have on them.
    One had 37AQ-1 and 5399. The other I assume is the serial number 558397.
    Thanks for any information you have.
    Alex
    37A is a Dictator. Q1is a regular coupe. 5399 is the assembly line sequence number. If the 558397 is
    on a plate on the left frame rail behind the left front wheel, it is the serial number but there should be one more number (it should have 7). Starting serial number for a South Bend built 37 Dictator with beam front axle is 5536001.
    Terry
      5399 is not the "assembly line sequence order" It denotes that this body tub was the 5,399th 37A Q1 BODY TUB welded up. But that doesn't mean it was integrated with the 5,399th 37A Q1 that was built.
