Weight of Lark versus Avanti
  • Weight of Lark versus Avanti
    Wondering if a Avanti has any weight advantage over a Lark . Reason is I wonder if a super charged 289 would work better in one than the other. I figure someone here will know ! Thanks !
    Randy Wilkin
    1946 M5 Streetrod
    Hillsboro,Ohio 45133
    No, the Lark is actually a little lighter (2 dr). Plus the center of gravity is higher, and thus weight transfer is better. The Avanti has the heavy X member like convertibles that weighs a couple of hundred pounds. The Lark would win in acceleration. Top speed probably the Avanti due to areodynamics.
    Bez Auto Alchemy
      Thank you! I doubt I will ever have either, but in my dream world it's nice to know !
      Randy Wilkin
      1946 M5 Streetrod
        Does the x-member really weigh a couple of hundred pounds? Years ago I estimated the weight of the I-beam style weldments using stock bar sizes, but I can't remember what the weight was that was generated.
        sigpic 1963 Studebaker Avanti: LS1 motor and T-56 transmission have been moved rearward, set up as a two seat coupe with independent rear suspension. Complex solutions for nonexistant problems.
          Some numbers/weights (pounds):
          1963 Lark two door V8s - Standard 2910, Regal 2925, Custom 2940, Daytona hardtop 3035;
          1963 Avanti - 3140.
          Of course, these are base weights exclusive of any options.
            The x-frame actually weighs only 75 pounds
              Yeah, I was gonna say unloaded one by my self so it couldn't be over 100#.
                Serious drag racers strain for every little advantage. The Avanti is carrying 230# more or 8%. The Lark would be a couple tenths quicker ET, but no difference in MPH.
                jack vines
                  All I know is the darned thing is more than 1/4" thick top and bottom, and runs most of the length of the center of the car!!!! It takes three people to load one into a pickup.
                  Bez Auto Alchemy
                    Pull out the hole saw and do a swiss-cheese job on it. i bet you can slim it down by 40-50 lbs
