Aftermarket Carburator for Supercharged 289
  • #16
    Originally posted by ken-renda View Post
    One supercharged car is a 2 barrel, any ideas of converting it and with regard to the R2 what happens (if anything) to the vac line from the supercharger to the top of the gas pump. Has anyone made an R2 Edelbrock conversion? I favor staying original but I do like a car to start and run correctly with minimum trouble. No one in miles of my location will touch an old Carter. So far the only down side is the ugly red Edelbrock sticker on the front of the carb. Ken, Deltaville Va
    [ATTACH=CONFIG]27147[/ATTACH]
    If your using a Edelbrock carb then I would suggest using the air box in post #10. The line going from the supercharger to the fuel pump is not vacuum. It is pressure to assist the fuel pump in overcoming the boost pressure of the blower. Although this pressure box would not have the OEM look, it does say Paxton & would eliminate any problems from the carb leaking without the pressure enclosure. You could run the 57/58 Golden Hawk setup with the 2bbl in it's pressure box, again not having the R-2 look but still functional.
    60 Lark convertible V-8 auto
    61 Champ 1/2 ton 4 speed
    62 Champ 3/4 ton auto
    63 G.T. Hawk R-2,4 speed
    63 Avanti (2) R-1 auto
    64 Zip Van
    66 Cruiser V-8 auto
    • #17
      What a gorgeous engine.
      • #18
        What Joe Roberts said; pretty stuff! BP
        Ayn Rand:
        • #19
          Thanks for the kind words fellas. This is going in a 1937 coupe express!
          • #20
            Originally posted by black9fourfour View Post
            @Packard8 - any particular reason you recommend the marine version?
            The marine version has seals around the throttle shafts and accelerator pump to comply with USCG safety regulations (fuel/vapor leaks can be catastrophic in an enclosed environment like an inboard engine enclosure).
            I haven't tried it, but many posts by users claim it is good to around 10 PSI boost without further mods.
            1996 Impala SS
            1967 Jag XKE FHC
            1963 Avanti R2
            1963 Avanti R1
            1956 Packard Patrician
            1948 Jag Mk IV DHC
            1909 Hupmobile Model 20
            • #21
              You are using the early 57 Golden Hawk blower mount. When the blower is installed there is not enough room for the 4 barrel design carbs. That is why the early ones were limited to a blown two barrel. There is not enough clearance for a four barrel carb.
              Start and Stage Your Studebakers
