I got a call from my neighbor telling me that when he got home, he noticed that one of my brake lights was on. I assumed that maybe he meant my headlights, as I went to a cruise-in this morning and had turned my headlights on during the way home.
So I run out there, and check, and sure enough, it's the brake lights. One is on, and one is off. It looks like the replacement brake switch I put on there a couple weeks ago got stuck in the closed position. No worries, switches are cheap.
The highly interesting part though was the drivers side brake light. The bulb appears to have burnt out after being stuck on for several hours. In addition though, the very center of the brake light has experienced its own failure:
The very center of the brake light lens appears to have melted in. My best guess is maybe the combination of the oppressive heat we've been having, coupled with hours of baking from the bulb did it in. The bulb being burnt out sorta makes me wonder if when the bulb went out, it heated up more, and that was the straw that broke the camels back, so to speak. The hole is concave, going into the housing. It almost looks like someone pushed the hole in it, but I cannot imagine a way to do that without cracking the lens. This lens had a indent to begin with right at the point of failure, so who knows if that also played a role.
The other side (both the bulb and the lens) are just fine. I even gently pushed on the lens with my finger to see if it would cave in at all, but it didn't, despite the bulb being on until i pulled the wire from the switch a few moments earlier.
Has anyone seen anything like this before? A switch failing and a bulb burning out are fairly common, but I've never seen a lens fail like that.
