How many automatics compared to manual transmissions were built for studebakers in certain models?
  • How many automatics compared to manual transmissions were built for studebakers in certain models?
    Curious as to why almost every Studebaker I look at on craigslist for sale or on ebay seem to be 3 on the tree manuals.. Were more manuals produced? were they cheaper to produce? are automatics rare?
    Granted I have only been looking at Larks, champions and starlight coupes... but maybe I just hit a patch of all manual vehicles..
    I am going to focus more on finding a 50-51 Starlight coupe come next spring and plan to spend around the $8000 range.. are there different versions of the starlight that came with the automatics?
    I think the main reason why you see so many manuals available is that Studebaker owners traditionally valued economy and Studebaker generally delivered that with 3-speed manuals plus overdrive in most models. Plus...Studebaker seemed to build mostly low cost cars...the factory built what dealers ordered. Look at the time period involved...automatics were available but not the norm except in higher grade autos from most manufacturers. Most everyone learned how to drive on a manual...not like today.
      1950 was the first year for the automatic transmission in Studebaker. It is going to be quite a bit rarer than a standard.
      The Starlight Coupe was a body style that was available in the Commander or Champion models.
      The '50 Commander and/or Land Cruiser had a 245 cid flat head six and was mated to the Borg Warner DG200 automatic or the Borg Warner T86 standard 3-speed or 3-speed w/OD.
      The '50 Champion had the 170 cid six and was mated to the DG150 automatic or the T96 standard with or without overdrive.
      1951 was the same as 1950 except, the Commander and/or Land Cruiser was fitted with the new 232 ohv V-8.
      '33 Rockne 10,
      '51 Commander Starlight,
      '56 Sky Hawk
        I think the other reason is that automatics in those days were less than reliable and few folks buying at the low end of the spectrum wanted tha huge repair bills related to automatics. The BW standard trans in studebakers usually outlasted the cars.
        ed ellis
        the "SUPER COUPE"
          I would guess that in 1950, fewer people were interested in the "newfangled" automatic transmissions, so fewer were ordered and produced.
          I wish you the best in looking for a Starlight coupe, by the way. I searched about 2 years before finding mine, but I was looking for a Commander specifically. I have found that most nice Starlights are in the $12 - 15k range, but you may get lucky and find a nice one for less.
          1950 Commander Starlight Coupe
          Regal Deluxe Trim
          Automatic transmission
          46k original miles, 4th Owner
            My 51 Commander State has the Detroit Gear transmission.
              My 1950 Land Cruiser was equipped with the DG200 Borg Warner automatic. Very nice riding and driving automobile!
              Granted, it was a top-o-line car for the 1950 lineup.
              Lt. Col. Jimmy Doolittle
                I believe the extra cost was by far the biggest factor. On both the Commander and Champion in 1950 the Automatic was a $160 option which amounted to approx 10% of the average cost of the car (e.g. A Champion Regal Deluxe 4-dr sold for $1565 F.O.B. factory). The overdrive was an extra $87 on the Champion and $93 on the Commander. "Whatever the question is the answer is money."
                Richard Quinn
                  It really depends on what year and Model you are looking at/for. As others have said early Cars 1950 to 1955 were rarely ordered with Automatic, especially those with 6 Cyl. Champion 170 cid Engines.
                  If you ever drove one you would know what I mean, there just is not enough power to push a 3100 Lb. car AND drive an Automatic Transmission.
                    The early automatics in general, not just Studebakers, were seen by many people as unreliable. I knew many people who avoided automatics. The extra cost would have also been a big factor. I still prefer an 3 speed with overdrive in a Studebaker.
                      It really depends on what year and Model you are looking at/for. As others have said early Cars 1950 to 1955 were rarely ordered with Automatic, especially those with 6 Cyl. Champion 170 cid Engines. If you ever drove one you would know what I mean, there just is not enough power to push a 3100 Lb. car AND drive an Automatic Transmission.
                      amen!!! i usually have to go to "low" (1st) gear to get out of the neighborhood on to the "main drag" if i see a vehicle within a 1/2 mile.
                      i ass-u-me that "Detroit Gear" is the "DG" "Borg Warner DG 200" - is that correct? gotta replace some leaking gaskets (which i have) and adjust the linkage, it goes to 3rd from starting off in "D" (2nd) way too early. going to be a long fall/winter working on her!
                      for the OP: there are automatics out there - more in the late 50's thru 66. and as mentioned, if you find a $8K bullet nose starlight - it's probably going to need a lot of work...
                        Originally posted by Corvanti View Post
                        /Cut/i ass-u-me that "Detroit Gear" is the "DG" "Borg Warner DG 200" - is that correct?
                        Yes and No, Technically the Studebaker Automatic Drive (3 Band) was called "DG-150, DG-150M, DG-200, DG-200M, DG-250, DG-250M" because it was made by Detroit Gear Div. of Borg Warner, so not really known as a Borg Warner.
                        "Borg Warner" usually refers to the Studebaker Flight-O-Matic version which is the Borg Warner Cast Iron case Automatic similar to those used by Ford, Mercury, Lincoln, Nash/AMC, Kaiser Jeep, '57-'58 Packard, Mercedes Benz, H.D. Aircraft Tow Vehicles etc.
                          I think what you're trying to say Rich is you can't burn rubber with one,but it will go down the road just the same
                          Joseph R. Zeiger
                            ... there just is not enough power to push a 3100 Lb. car AND drive an Automatic Transmission.
                            Rich, I must assume you are referring to the Champion. My '51 Commander with DG200 can light up first and chirp second!
                            '33 Rockne 10,
                            '56 Sky Hawk
                              Post #9= "It really depends on what year and Model you are looking at/for. As others have said early Cars 1950 to 1955 were rarely ordered with Automatic, especially those with 6 Cyl. Champion 170 cid Engines."
                              If you ever drove one you would know what I mean, there just is not enough power to push a 3100 Lb. car AND drive an Automatic Transmission. "
