Wheel cylinders for a 48 M-5
  • Wheel cylinders for a 48 M-5
    I am trying to rebuild the brakes on my 48 M-5. I found the wheel kits at SI but mine are so rusted that the cups and rubber won't even move in mine. Anybody know of any wheel cylinders to fit the truck. I at least need the fronts. Thanks Tom
    The New Wheel Cylinders are only available for 1949 "R" Trucks forward, to most others up to 1964.
    Unless some very old stock stashed away in a deceased person's closet is discovered, you will be limited to sleeving the old ones unless you update the entire Brake System.
      Didn't I read sometime back on Truck Talk that F..d wheel cyls. from Speedway Motors will fit a M5????
      Or was I dreamin?
      Jim
        This could be your golden opportunity to swap to late model V-8 or late model Champ front brakes.
        The Champs should be a bolt on from the backing plates out. The V-8's require that you bolt up the 4 holes that match your spindles, and re-drill the other 2 holes. Either way it greatly improves the braking.
          You should be able to adapt a grease fitting to the cylinder and push at least one piston out with a grease gun.
          Claude Chmielewski
          Studeski
          http://www.studeski.com
          Fillmore, Wisconsin
          47 M-16 Truck
          53 2R5
          60 Lark VIII Convertible
          60 5E7 Champ pickup
          62 GT Hawk 4 speed
          63 Lark
          63 GT Hawk R2 4 speed
          64 Commander Wagonaire
          64 Daytona Convertible
          50 Champion Regal (parts car)
          36 Dictator
          36 Dictator in pieces
