Carb Float Don't Float
  • Carb Float Don't Float
    My 1964 Wagonaire is on the road Daily, but the float has a small hole.
    I'm looking for one. it's from a 289 2 barrel Stromberg WW 6 130.
    She run fine, but i need a float. If someone has one, send me a PM.
    Thanks
    Steve
    Can you dry out and patch the float with epoxy?
    60V-L6 - 60 Lark convertible
      WW Strombergs used stamped brass float assemblies that should be readily repaired by locating the leak area and soldering as required. I have bought new floats from Studebaker International also, but I hadn't ordered any recently so I can't speak for the current availability.
        I just pulled a WW 6 130 off my car to swap in a 4bbl Carter AFB. I also have a second Stromberg (Thinking a 127 or 128). I don't need either and would part with them cheap. Shoot me a PM if interested.
          For clarification, the carb I pulled off my car was barely functional. I was going to do a rebuild on it, but my mechanic thought it might be too far gone even for a rebuild. Then I found a Carter AFB.
