1961-66 Lark type; hydraulic clutch conversion thoughts?
  • 1961-66 Lark type; hydraulic clutch conversion thoughts?
    Presently Studeless at the moment due to no money but things seem to be picking up slightly here.
    Pondering getting another Lark type with a stick but would loooove to pitch that Rube Goldbergesque clutch linkage since I plan to swap in a non Stude motor. I plan to keep the original pedal though. Would a Camaro/Toyota, etc. clutch master work or would I be looking at a lot of fabbing?
    I'd do a search in the tech forum. Junior has a good one on the under floor conversion w/T5, I'll be finishing mine up in a week or so w/T56in my Avanti with suspended pedals but I don't want to short anyone else that has posted either.
    Do yourself a favor and swap in the complete engine/trans from the donor car w/hydraulic clutch as standard equipment and then you'll only need to figure out how to adapt the clutch pedal and possibly a clutch master cylinder.
    You could consider a hydraulic TO bearing as later GM offerings had them as well as the aftermarket. Just depends on what you are going to install.
    The biggest issue is getting the clutch pedal/clutch master cylinder stroke, size and volume correct.
    Google is full of data on those variables.
    Bob
      Here's a good source for what you seek.
      http://americanpowertrain.com/c-3005...h-systems.html
