Need Stromberg rear air entry 2-bbl
  • Need Stromberg rear air entry 2-bbl
    Greetings, All,
    Would appreciate a shout from anyone having an extra Stromberg 2-bbl with the right angle air intake. These were used on the early V8s at least up through 1956. Please contact me off list at PackardV8@comcast.net.
    thnx, jack vines
    Thru 58 on sedans. Jack, there's some serious difference to CFMs between early ones and later ones. What' it for?[?]
    Miscreant adrift in
    the BerStuda Triangle
      Miscreant adrift in
        These are not back draft, or side draft, carb's. They are down draft carb's. that simply have a right angle air horn attached to the top.
        1959 DeLuxe pickup (restomod)
            Ahh, yeah Gary, but we knew what he meant by it. Would it have been more specific if he'd asked for a downdraft???[)]
            Miscreant adrift in
              Miscreant adrift in
                Jack,
                I have a couple and, I see from your profile you live in U.S.A. That's real close to me.
                Like Bob said, what's it for? 232, 259, 289?
                  Jack,
                    Greetings, All,
                    Thanks for the interest. I found an old Spenser aluminum intake which mounts four 2-bbl carbs and I want to try it on a strong 299" I am building. It looks like the 50s all over again. Standard Surplus Company (before they became SASCO) sold them for $69.50 back in the day. Four AAV Strombergs went $38.50. They were available in 1 3/16" or 1 7/16". For some reason, the WW Strombergs were $15.95 each, vs $9.95 for the AAV. The Carter WCFB 4-bbl was $25.00.
                    The one rear-facing inlet Stromberg carb I have is from a '56 259". Biggs, can you post a list of the CFM of this and other years? Wouldn't want to mix 'em up too much.
                    thnx, jv.
                      Greetings, All,
                      thnx, jv.
                        Miscreant adrift in
                        Yes, Bob/MrBiggs, you and I and many others knew what he was referring to and I did see your smile face. As you know, I work to keep Studebaker history/facts correct. There may be new people that would think that Studebakers used a backdraft carb. in the '50s or that the carb with the right angle, rear facing, inlet is actually a back draft carb.
                          Miscreant adrift in
                            Hi, Gary,
                            Technically speaking, what would be a backdraft carburetor? There are downdrafts, sidedrafts and updrafts, but AFAIK, no backdrafts. I just used it as a shorthand notation for "Stromberg WW 2-bbl downdraft carburetor with a rear-facing air inlet as original equipment on mid-1950s Studebaker V8s."
                            jv.
                              Hi, Gary,
                              jv.
