Bellcrank to carb rod needed
  • Bellcrank to carb rod needed
    Somehow I broke the ball stud off the end of my throttle bellcrank to carb rod (289 4 bbl). Looking for a replacement in exchange for cold hard cash and gratitude.
    Actually, I only need the one part of the rod, part # 1539610 as pictured below. PM me if you have one you'll sell.
Name:	Photo Mar 13, 8 28 39 PM.jpg
    Bob Shaw
    Rush City, Minnesota
    Was a time when you could just buy the ball stud at your local auto parts store, mom&pop and or NAPA.
    Dorman products made them.
    Lt. Col. Jimmy Doolittle
      I'm pretty sure ball studs are still available but on the Sudebaker, the ball stude is crimped in the rod and apparently not replaceable versus the spring-loaded ball stud gripper style (for lack of a better description) that was used on my '41 Ford. Wish I could do that with this one. I suppose I could get those pieces from an early Ford V/8 vendor and make up my own rod like I did when I put two deuces on the flattie.
      Bob Shaw
        Hi Bob, Yes, on closer inspection I see the crimp. As a suggestion, could you take a Dremel tool with a cut off wheel attachment.
        And cut the barrel of the throttle ball end lengthwise and released the crimp, threaded the rod and replaced the end?
        Only if you couldn't find the correct Studebaker replacement part of course.
        Bill
          I have replaced more of those than I care to remember. It is the weak link in the accelerator linkage. Last time, I made an adapter and used a ball swivel that has a hole for a 1/4" bolt to pass all the way through, and a nut on the other end. I don't think I'll ever be replacing that one, and plan the same mod on the other two Studes when the inferior swivel craps out.
            [ATTACH=CONFIG]22079[/ATTACH]
            Tom Karkiewicz (574.287.5834) ...the Stude Vendor with the "White Bus" from South Bend usually has a good supply of NOS & good used ones. He has several different ones, so best to take some measurements from your old rod before picking up the phone.
            GOOD LUCK!!!
              PM sent to you.
                I bought a new one from SI a couple of years ago. Might they still have them?
                  I checked their catalog and searched the part number via their website and came up empty. Of course, that doesn't mean they don't have it.
                  I'll probably call Tom K. as suggested. I've gotten a number of small parts from him recently and he is always great to work with.
                  Or, I may just make one using an Edelbrock #8010 throttle rod extender. Looks like that would work. Gonna stop by The Carburetor Shop and check it out.
                  Bob Shaw
                    Check this older thread in ADVANCED SEARCH
                    Thread: 57 GH Throttle Pressure rod spring clip needed
                      Thanks for the suggestions, all. And thanks to another forum member the replacement part is on its way. Woo hoo!
                      Studebakers are great. Studebaker people are the greatest!
                      Bob Shaw
