Is voltage regulator shorted out?
  • Is voltage regulator shorted out?
    I have just purchased a 1960 Lark and the Batt wire was not connected to the voltage regulator. The field and armature wires were connected from the generator. When I tried to cannect the battery wire it just arced as it would if it was a direct short to ground. I believe I had this happen on my corvair and I replaced the regulator which fixed it. How do I test to see if it is shorted out? I would think I should use an ohm meter/continuity tester between the battery terminal and a ground. I'm thinking that I should also check both generator posts to the case.
    Can someone verify what I should do? I don't want to just buy a regulator if that's not the problem because they are about $85.
    Avantidave
    1978 Avanti II
    The Regulator should be isolated from ground, so I would think the issue is in the generator.
      Take the cover off and see if the points are welded together.
      Claude Chmielewski
      Studeski
      http://www.studeski.com
      Fillmore, Wisconsin
      47 M-16 Truck
      53 Commander Regal HT
      53 2R5
      60 Lark VIII Convertible
      60 5E7 Champ pickup
      62 5E7 Champ no box
      62 GT Hawk 4 speed
      63 Lark VI parts car
      63 GT Hawk R2 4 speed
      64 Commander Wagonaire
      64 Daytona Convertible
      50 Champion Regal (parts car)
      36 Dictator
      36 Dictator in pieces
