Vacuum switch for wig-wag stoplight
  • Vacuum switch for wig-wag stoplight
    Still trying to get my wig-wag stoplight set up. I've been told that propane safety switches as used on forklifts can be used to activate the wig-wag, but all the local forklift places laughed at me when I asked if they had any 6-volt units. Does anyone out there have a recommendation (and a source) for what I might use to provide vacuum to the stoplight when I step on the brakes? Thanks. Tom
    If they are not too expensive, you might try a 12 volt one and see if it runs on 6 volts. Sometimes it will work. There are lots of 12 volt relays that still work on 6 volts.
    BTW, when asking for something out of the ordinary, and you get laughed at, that only means the laughers are a--holes with limited imagination.
    60V-L6 - 60 Lark convertible
      Excellent advice. I found one more forklift parts place and a knowledgeable counter man. He fixed me up with a 12-volt unit hat works great on 6-volts on the bench for $56. Thanks. Tom
        Since you are operatig using a vacuum instead of pressure you may need to reverse the in/out port connections.
        Or maybe not -- depending on the seal construction.
        Lark Parker --Just an innocent possum strolling down life's highway.
