1950 Champion axles
  • 1950 Champion axles
    Does anyone have 2 good rear axles for a 1950 Champion with the 23 differential that they would like to sell? I would also take a complete differential assembly if one is available. Bud
    You can use 47-50 Champion axles.
      RadioRoy, thanks for the tip. Bud
        Will an "assembly" out of a 53/54 wagon fit/bolt in ?
        I've got a 44 if your interested and if it will fit.
        I'm also in SoCal.
          The axle/differential assemblies got wider in 53, so yours will not fit. 47-52 are the narrow ones and 47-50 are the ones with the small spindles and the 4 lug brake drums.
            I've got 4 1950 Champions that I'm planning on making 3 out of. At least 2 of the builders will be modified drivetrains, so that's 3 rear differentials that I don't need. I'll bet at least one of them is what you're looking for.
            1950 Champion Convertible
            1950 Champion 4Dr
            1955 President 2 Dr Hardtop
            1957 Thunderbird
              I got one you can have. You pick up. I am located outside of Sacramento, Ca
