What is the hardest Studebaker Fuel pump to replace??????
  • SN-60
    I've found that unbolting the power steering pump on Studebaker Avantis and C/K's with p/s, and resting it on the engine (with hoses still attached), is a lot easier than trying to work around it
    on a V8 fuel pump replacement.
  • deco_droid
    Originally posted by unclemiltie View Post
    What Studebaker has the hardest fuel pump to replace?
    I just had to replace a fuel pump on a 50 Commander. It has 4 lines going to it, is hard to get onto the engine, you have to stand on your head to work on it and the clearance is not much. Getting all those fittings put on without crossing threads was a challenge. While working on this one definitely considers the merits of an electric pump and forgetting about the pump driving the wiper motor.
    This is harder than any V8 or champ 6 fuel pump I have replace.
    Any other hard Studebaker pumps to replace?
    Hopefully you don't have two more to go!
    By the way, how many miles were on this one and what was the problem that caused you to need to replace the fuel pump? Just wondering in case I ever have this issue...
  • HyBall
    65/'66 V8 shoe are pretty impart with that dull swimmer you bang to piss trusty doesn't get away and they are awful waterproof to the framing. I gave up on a '65 Car and went block-off sheet and electric ticker.
  • 41 Frank
    While putting a fuel pump on a small block Chevy motor can be frustrating exercise, the easiest way to keep the push rod up out of the way, while you bolt up the pump goes like this. Most earlier Chevy small blocks have the drilled bosses present at the front of the block where in the mid fifties Chevies had their front motor mounts. These bosses still have the holes drilled and tapped. One hole will have a bolt stuck in it as it is open to the fuel pump area, to prevent oil leakage. Remove this 3/8ths x 1" bolt and temporarily replace with a 1 1/2" bolt. Screw this in finger tight until it contacts the fuel pump push rod and it will hold the rod in place while you bolt up the pump. (Pump will install easier if the rod is on the low side of the eccentric, rotate engine to accomplish this). Reinstall original short bolt when finished. Makes it about a 15 minute job.
  • Studebakercenteroforegon
    All you have to do on '65 - '66 V-8's is remove the sub-plate (behind the fuel pump mounting flange) then remove the fuel pump push rod, smear it with some grease and re-insert it. The grease will hold it up out of the way so you can readily install the fuel pump. Almost any auto parts store will stock the gasket that goes between the sub-plate and the block.
  • 53k
    '65/'66 V8 pumps are pretty mean with that stupid plunger you have to make sure doesn't get away and they are awfully tight to the frame. I gave up on a '65 Cruiser and went block-off plate and electric pump.
  • What is the hardest Studebaker Fuel pump to replace??????
